![]() | Home > Maintenance & Mods (L405) > Power bank recommendations |
| Arch Stanton Member Since: 26 Apr 2012 Location: chavshire Posts: 536
With my L405 being picked up hopefully this week, I am getting myself sorted to try and keep it on the road as much as possible. The battery was flat as **** when I saw the car in the dealers and they said they would attempt to give it CPR, if unsuccessful, they'd fit a new battery. I'm anticipating that they will try it on and leave the old battery on so, again, I'm anticipating that it will be a bit poorly afterwards and more likely top fail, leaving me stranded.
| Danb_220_2019 Member Since: 02 Jan 2023 Location: Suffolk Posts: 262
Go for a GBX if you're going to go NOCO.
I'll look into the GPX55, looks just the job thanks
| Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631
I bought a GBX75 - as above, way better than the earlier/cheaper versions - it was on offer on Amazon for £199 (think it was a mis-price), I've never had to use it on my own car but it will start other large engined vehicles quite happily. Note that the rating is for a fully charged pack, I went for the next one up to guard against having a less than fully charged one, should I need to use it. |
can they be left plugged into the car in a USB port to make sure it is always topped up? Onto my 2nd FFRR, this time an L405 5.0L SC AB in SVO Palette black. |
Dunno TBH - I've never done that as batteries, Lithium or otherwise, only have a limited number of charge/discharge cycles in them. Lithium batteries in particular don't like to be constantly topped up to 100%, |
They can be left plugged in but it's not recommended, and tbh I don't find mine discharges much. Tend to plug it in to charge every couple of weeks when I clean the inside of the car out. |
cheers all, just need a car now to go with it Onto my 2nd FFRR, this time an L405 5.0L SC AB in SVO Palette black. |
| TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 675
I have a GB70, it was a god send on the old L322 which seemed to require a new battery every 2 years.
