![]() | Home > Technical (L405) > Weak battery and terrain response |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8808 ![]() ![]() ![]() |
You can try disconnecting the battery, give it a full charge then reinstall it, that is the only reset you can do without using a diagnostic tool which is your next action if the disconnect doesn't work... |
funnyguy1 Member Since: 11 Mar 2010 Location: Sun Valley, Idaho Posts: 392 ![]() ![]() |
Got it! Thanks Pete |
I tried disconnecting the battery, then charging it, then hooking it back up but it did not change the unresponsive "terrain response" knob. |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3813 ![]() ![]() |
I had the same issue with the rotary gear knob - total lockout - it was the battery goosed - bought a new Halfords battery and issue immediately solved 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
