Home > Maintenance & Mods (L322) > Side Steps .... Aftermarket options
Superspoons
England 2006 Range Rover Vogue SE 4.2 SC V8 Zambezi Silver
Hi and a Happy New Year to you all Thumbs Up
After an 'incident' before Christmas, my passenger side step has broken at the back and is bent down - a combination of rust and heavy use..
I've searched the usual places and found these cheap replacements -
https://www.lrparts.net/vub503660-range-ro...lable.html
or
https://www.ebay.co.uk/itm/383447976193?mk...9rAGAAAAAA
Has anyone any experience of fitting these and the quality ? Do the holes line up, is the metal made of wafer thin steel ?
Open to other sources / secondhand pair to.
Thanks in advance. Gavin
2005 Range Rover Vogue SE 4.2 Supercharged V8
Follow my 4.2 Supercharged antics -
https://www.fullfatrr.com/forum/topic63354.html
https://www.instagram.com/l322_supercharged/
https://www.youtube.com/channel/UC8ChHNSdscnJarKjBLd_IAg
https://www.youtube.com/@ChallengingClassics
Post #652424 3rd Jan 2023 12:54pm
Range Rover L322
Some hopefully useful info about this here:
https://www.fullfatrr.com/forum/topic52954...side+steps
Of the two options you mentioned I would probably buy the ones from LR Parts as you have an immediate part of recourse with an acknowledged and known dealer in case of an issue. Mine were from 4x4 Direct here £189.99. I would buy them again.
https://direct4x4.co.uk/products/range-rov...&_ss=r
The pattern is the same as the OEM. the only difference were some screws vs rivets. The paint job on them was a bit thin. I live in the middle of the sea (really) and after 3 years my ones from 4x4 Direct are pristine - I painted the underside, then painted them again. and a third coat . I used Hammerite last time but I would use Raptor coating next time, it is GMC truck bed liner and I have the whole underside of my car done in it. It's great. Good luck.
. 2012 L322 4.4 TDV8 AB low mileage - a peach
1986 V8 Defender 90 County ex-Swiss Army - Red everything....
My preferred Independent: Roy Hardy. R & B AUTOS LTD, 20 Brook Road, Wimborne, Dorset, BH21 2BH 07500 866775‬ (Ex LR Chief Technician)
Post #652440 3rd Jan 2023 2:33pm
Superspoons
That is great info Thumbs Up - thank you very much. I did search on here but for some reason that thread didn't show Gavin
Post #652441 3rd Jan 2023 2:41pm
