Home > Technical (L322) > Accelerometer flat = Limb mode/Gearbox/Traction issues
Tiprat
Good morning everyone, happy New year to you all
As above really, several times over the Christmas period I've had need to plant the accelerator hard down for more power and the car goes straight into limp mode showing engine gearbox traction issues, turn car on and off and it clears everything and car drives normally, if I lightly put the accelerator down it gives me all the power I want and accelerates as it should.
There is no diesel showing under the engine cover, suggesting a leaking injector or cracked manifold ect, all the pipes look ok can't see any cracks ect, cleaned the 2 MAF&MAP sensors even swapped them over with each other. Having put my diagnostic machine on Autel MK808 all I can find is the screenshot below.
Can anyone over any suggestions as what to look at
Regards
Tiprat.
 Borrowed Grey 2002 3d 204k for a year
Now own a 2007 Java black Vogue SE 3.6TDV8 160k
Post #652618 5th Jan 2023 12:42pm
