![]() | Home > Technical (L322) > Centre console stowage box - what is the blank blanking? |
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 710 ![]() ![]() ![]() |
On the earlier face-lift cars there was a mobile phone connector for very specific Nokia phones. No light I'm afraid Paul,
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 570 ![]() ![]() ![]() |
I can confirm, as mine has exactly that & No Lamp. |
That'd probably explain it - and the other odd mouldings between the two halves. It's probably the same or similar to the hardwired phone kit in the L319/320's. A light would be useful though, I might just mount something in the blank with a tilt switch to control it... |
Thanks. |
I managed to find a 'warm white' capstan panel light, mounted it on the blanking plate, along with a tilt switch which is held at an approximately 45 degree angle with a liberal amount of hot melt adhesive, the wiring has some adhesive lined heatshrink sleeving to protect it where it goes over the lid pivot bar, I've connected it to the centre console rear power sockets with a 3A fuse.
TDV8 Paul Member Since: 30 Nov 2020 Location: Tadworth Posts: 224 ![]() ![]() ![]() |
Mine has a slider with a padlock on it so it’s some sort of lock/unlock that I’ve not worked out yet 😂 2009 (2010 MY) 5.0 Supercharged Autobiography
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 303 ![]() ![]() ![]() |
Nice mod, well thought out. Good job! TDV8 4.4 2012 |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16392 ![]() ![]() ![]() |
