Home > Technical (L322) > 4.4 TDV8 catalyst temperature sensor
iainvr4
2004 Range Rover Vogue Td6 Java Black
Hi all looking for some guidance my 2011 4.4 tdv8 has came up with restricted performance fault P042D bank 1 sensor circuit 2 catalyst temperature sensor high input. Could anyone guide me to this sensor please? TIA
Post #652992 8th Jan 2023 3:58pm
Dolphinboy
as a starter for 10
faults in oxygen sensor
Catalyst temperature sensor harness might be damaged or shorted
poor electrical connection in the catalyst temperature sensor circuit
catalyst temperature sensor fault
exhaust air/fuel mixture incorrect
Post #653046 9th Jan 2023 1:56am
JayGee
Could this also be that the temp is actually too high and the sensor is fine? 2012 TDV8 Vogue (L322)
Post #653052 9th Jan 2023 10:39am
iainvr4
I did think that. The sensor is the one in between the cat and the DPF so took it on a long run tonight and no fault at all temp went up to 600c on bank 1 sensor 1 & 2 but not the others. Not quite sure how the temperature there would get so high compare to the one before it would understand if sensor 1 was way high due to a blocked cat. Unless the dpf was clogged but not triggering it’s warning light.
Post #653124 9th Jan 2023 10:42pm
