Home > Technical (L322) > Brake Fluid/non starting
Rosco
My L322 ( 2011 TDV8) has now thrown a wobbly re brake fluid and wont start, I have topped it up but peddle still goes to the floor, I suspect brake pipes, any suggestions ?? Thanks Thumbs Up
Post #653120 9th Jan 2023 10:06pm
Baltic Blue
Cunifer Rolling with laughter
Post #653123 9th Jan 2023 10:18pm
p38arover
Australia
I think he’s trying to peddle it ‘cos the pedal goes to the floor. Or does he need to pedal it like Fred Flintstone because it won’t start? I’m confused. 🤪 Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #653126 9th Jan 2023 10:46pm
garyRR
Failed vacuum pump?
Clear any fault codes, see if it will start. You can diagnose if the pedal goes to the floor and gradually returns over a period of time (with the engine running). After a few presses, the pedal should go to the floor again.
Entirely possible due to age and mileage. If it is, no need to worry, it's not a big job.
If you're losing fluid (should also be visible on the brake hoses and then on your driveway forever), then I'd suspect brake lines, obviously. 2015 Range Rover Autobiography 4.4 SDV8
Post #653127 9th Jan 2023 10:47pm
Rosco
p38arover, as indeed you craftily worked out I am trying to peddle it (see for sale section) nothing to do with the inactive brake PEDAL, my bad Rolling with laughter
Post #653171 10th Jan 2023 1:11pm
Mikey
New stuff needs to see brake pressure before it will crank
If you have a leaking pipe, that'll likely be the issue Thumbs Up
Post #653227 10th Jan 2023 9:06pm
p38arover
Australia
^^ lol Rosco Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #653245 10th Jan 2023 10:48pm
garyRR
Just to bump this thread, I gave mine an under-chassis clean earlier in off-road height and then turned on the ignition to drop it to access mode to then wash the car (letting the parking brake off in the process). The depressing lost the brake vacuum and I really had to stamp on the brake pedal very hard before it would allow me to start it later on.
Right in saying the new ones need to register brake pressure before they will start.
Worth a try if you haven't already. 2015 Range Rover Autobiography 4.4 SDV8
Post #653459 13th Jan 2023 4:29pm
