![]() | Home > Technical (L322) > Steering judder under moderate braking at high speed |
TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 436 ![]() ![]() ![]() |
Had a similar thing last year, it turned out to be ever so slightly worn drop links causing the judder. Changed and now perfect. 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3339 ![]() ![]() ![]() |
Thanks - that's an easy enough fix! 2012 TDV8 Vogue (L322) |
Replaced both outer steering tie rods and the judder is much reduced but still noticeable. Car feels much nicer to drive though as the steering is more precise and it doesn't 'float' in a straight line at speed. I'd kind of got used to this as the nature of the car but glad it's now gone. 2012 TDV8 Vogue (L322) |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1342 ![]() ![]() ![]() |
My brakes gave me similar symptoms with a light shudder felt through the steering wheel and it was a rear brake caliper at fault. With new ones fitted everything was back to smooth braking. Don't know why it made the steering wheel shudder though! I can do high speed braking with confidence now. |
I replaced the rear callipers last year and it started when the front disks and pads were replaced. I think I'm going to have to remove them and see if they are mated cleanly against the hubs 2012 TDV8 Vogue (L322) |
jagracer Member Since: 14 Aug 2021 Location: Norfolk Posts: 124 ![]() ![]() ![]() |
Hi, when I was racing XJ-S's the discs used to warp so bad that the caliper pistons would knock back enough to require pumping the brake pedal at 145 mph to get the pads back against the disc. I tend to agree that the discs might not be hard against the hub face. Its worth putting a dial indicator to check the runout, and wobble the hubs about to check for bearing movement as well. |
