![]() | Home > Technical (L322) > Audio Amplifier Module fault codes B1A01-13 & B1A02-13 |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3329 ![]() ![]() ![]() |
Are these actually faults you can hear i.e spaekers and amp not working? If they are GAPIID fault codes then there are numerous false / spurious codes thrown with every fault check. 2012 TDV8 Vogue (L322) |
bearhouse Member Since: 18 Jul 2020 Location: Hemel Hempstead Posts: 10 ![]() ![]() ![]() |
There be honest, they are fault codes. I've get to see if I can hear / identify the faults. But, the codes have come up twice when the garage have scanned for faults. |
Gaby13 Member Since: 27 Aug 2024 Location: Milton Keynes Posts: 2 ![]() ![]() ![]() |
Hi, do you fix the problem?
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1405 ![]() ![]() |
Everyone has these fault codes
The sound doesn't work on mine |
Ah that's a different matter, but those cides have been standing on mine since I got it, everything works fine, so I don't think investigating those will help you... |
