Home > Maintenance & Mods (L322) > Tdv8 4.4 front differential unit change, advice saught.
johnboyairey
Guys, my front diff is whining, I’ve secured a secondhand (same ratio) diff, and I’m ready to replace it… but I can’t find any experiences on the job on this forum for my engine…. I’m assuming to disassemble the suspension arms and pull out the short driveshaft, and with the longer one, similarly dismantle, and pull it out enough, so that the unbolted diff will then be free to remove. So with the front prop shaft removed, does the diff just come out, towards the transfer box, or drop through subframe, or is there a lot of subframe dismantling to get the thing out? I’ve seen some similar questions on other engines, but not for the 4.4 Tdv8.. thanks.
P.s. there’s nothing on YouTube either.
Post #653774 17th Jan 2023 10:37am
kevinp
Have you downloaded the workshop manual?
I've just had a look and it shows what to do.
Post #653777 17th Jan 2023 10:57am
GGDR
If you download the turbo drain mod doc, the diff removal is included
EDIT: Also what KevinP said
. Cheers, Greg
Post #653810 17th Jan 2023 4:58pm
diesel Dave
Once everything is unbolted, prop removed and drive shafts out it does wiggle out through the side of the subframe, its a tight fit but it will come out, just watch you don’t trap you fingers getting it out as its quite heavy. Good luck Thumbs Up
Post #653844 17th Jan 2023 11:22pm
johnboyairey
thanks guys... when the weather turns, I will get on with the job. and report back.
Post #653885 18th Jan 2023 1:54pm
