![]() | Home > Maintenance & Mods (L322) > air pipe problem |
Danb_220_2019 Member Since: 02 Jan 2023 Location: Suffolk Posts: 262 ![]() ![]() ![]() |
I'm no expert on the TD6 architecture, but that looks... Broken. |
The pipe looks fine to me. The rubber open end of the pipe simply slides over the plastic top bit. Lubrication helps. No clips or anything involved.
littlecub Member Since: 02 Apr 2013 Location: Ulverstone,Tassie Posts: 327 ![]() ![]() ![]() |
Thanks for the tip Nicedayforit.
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238 ![]() ![]() ![]() |
same advice as above from me, mine was not a tight fit, so where the pipes overlap I simply drilled a tiny hole through the pipes once they were correct position and fitted a small self tapper screw, no problems since then |
