![]() | Home > Maintenance & Mods (L405) > Importance of regular servicing!! |
| kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1364
| Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1442
Yep every 3 months for me. I guess there a few owners who ignore the app or the dash service notification.
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
WOWSERS!!! Not seen one that bad before... |
My top tip to get as much old oil out as possible is;
| ABAB Member Since: 02 Feb 2017 Location: GB Posts: 288
Basil, I told you not to use O’Reilly! 2016 SDV8 AB |
Next you’ll be dropping the sump to paper towel the innards sir 🥴🥴🥴 1st sign of madness that is sir |
Ahhhh brilliant… Love that… |
I've been mad for quite a while now Craig. |
| Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 409
If only that was easy on these cars... I need to remove the sump on mine to change the oil level sensor and have been told it is a 10-hour job involving dropping the front subframe ... Current: - 2017 L405 3.0 V6 Autobiography Sold: - 2013 L405 4.4 TDV8 Vogue - 2004 L322 4.4 Vogue (BRC LPG) - 2002 L322 4.4 HSE (having fixed timing chain guides) - 2000 P38 4.6 Vogue (BRC LPG) - 1981 2-door In-Vogue - 1980 Ex-Army SIII LWB - 1976 SIII LWB - 1968 SIIA Stripped for parts: - 2003 L322 4.4 Vogue |
| Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601
that is bad!! why do people spend so much on a car then just do not have them looked after?
| GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2773
Has the short wiring harness from the side of the sump been fitted? If not then fit it first to see if it cures the problem. |
| Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238
Nice tip Pete, as for first sign of madness CTC, we're all mad, we own FFRR's |
The purpose of the short wiring harness is really a temporary fix to prevent oil seeping further into the wiring loom, rather than fix a faulty sensor. See this thread: www.fullfatrr.com/forum/topic56693.html Current: - 2017 L405 3.0 V6 Autobiography Sold: - 2013 L405 4.4 TDV8 Vogue - 2004 L322 4.4 Vogue (BRC LPG) - 2002 L322 4.4 HSE (having fixed timing chain guides) - 2000 P38 4.6 Vogue (BRC LPG) - 1981 2-door In-Vogue - 1980 Ex-Army SIII LWB - 1976 SIII LWB - 1968 SIIA Stripped for parts: - 2003 L322 4.4 Vogue |
Merchy -interested in the cause of the cracks (retired dark side |
