Home > Technical (L405) > Timed Climate question
This morning was the first time I've used the Timed Climate using my phone.
Whilst the engine was running and I had set the tempt to get to 27 degrees, the front and rear screen heaters were not activated, and considering it was minus 5 they should have been. My Discovery always put them on automatically - is there a reason why they were not activated?
Full tank of fuel and no battery issues (as far as I know) Discovery 4 HSE
1993 90 Tdi
Post #653876 18th Jan 2023 11:08am
James W
Saudi Arabia 2017 Range Rover Autobiography SDV8 Siberian Silver
I've always wondered this too, it would make sense if the engine is running. So looking forward to any explanation Laughing FFRR SDV8 Autobiography
Post #653884 18th Jan 2023 12:49pm
DrF
Should be in your settings on the vehicle, make sure they are set to come on, i had the same with my daughters Discovery Sport and my sons Evoque, you need to go into the main settings screen for climate and from memory set it to activate the front and read screens.
Post #653924 18th Jan 2023 6:16pm
James W
Hmm will take a look! Thumbs Up FFRR SDV8 Autobiography
Post #653945 18th Jan 2023 7:59pm
I didn't know there were settings for timed climate other than the target temperature.
Having just gone through the iGuide, its worth noting that Timed Climate isn't the same as Remote Climate.
Remote climate starts the engine to do the warming up, whereas Timed Climate uses a timer setting from the car or, a remote key fob to activate. Mine doesn't have this.
The one I am referring to is simply managed by the Land Rover InControl app on my phone.
So this morning, same scenario, iced up and the screen WERE defrosted! Classic Land Rover. Rolling with laughter Discovery 4 HSE
1993 90 Tdi
Post #654006 19th Jan 2023 10:51am
