Home > Technical (L322) > FBH Operating Parameters Question
Ajmngn
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
Hi all, another FBH question:
In short, what is the lower V cutoff for the FBH? Vehicle manual does not say.
I’ve had mine set to come on for the normal 30 mins at about 0545. It’s been 3-4 degrees below zero here overnight so well in scope for operating. The heater is coming on but cutting out after about 15-20 mins, not managing to complete the cycle. There’s plenty of fuel, the vehicle is stone cold having not been started for many hours, so all I can think of is that the voltage hits the minimal threshold and cuts out.
I have a cheap battery monitor and the graph from this morning is below:
You can see the voltage is a reasonably healthy 12.3V, drops to something like 11.6-11.7V whilst FBH runs, manages just over 15 mins, then goes back to about 12.2V
Before anyone says that starting V is too low, I have contributed to many other threads on this topic and am convinced this is quite normal and within BMS parameters. I have a battery less than 1 year old, a new Denso alternator less than 8 months old, and monitor the battery V very regularly. Due to the way BMS operates, it is very rare that I see 12.4V or above before starting the vehicle, especially in winter.
Therefore if the cut off is something like 11.6, this seems a little high. Can anyone add any detail on this threshold?
Many thanks in advance as ever! 🤣 Andy
2010 4.4TDV8 Vogue SE in Santorini Black with Ivory interior
2017 Audi SQ5 3.0 V6T Quattro in Volcano Red
2001 Audi Allroad 2.5 TDI manual with low-range in Highland Green (Currently SORN whilst undergoing some serious restoration!)
Post #654567 24th Jan 2023 12:40pm
Ajmngn
🤣🤣🤣I think I’ve just answered my own question after re-checking the WM. Doh!
Seems the diesel models are limited to only 20 mins and not the full 30. I missed that when looking earlier, and would mean that my FBH is therefore operating as expected.
Also, looks like the cutoff is 10.5V +\- 3V for more than 20s 👍 Andy
Post #654568 24th Jan 2023 12:50pm
jaguar3
Estonia 2011 Range Rover Vogue SE 4.4 V8 Baltic Blue
Last winter I had exactly the same thing, FBH cuting of after apr. 18mins of work. Sometime not starting at all. I test it together with battery charger, same Censored . So its not about battery voltage I suppose, something else cut it of.
I give up and buy a new analog FBH (to avoid any issues in future). Analog FBH not communicate with the HVAC so nothing can cut it of. And also now it working as long as I wannt.
Post #654570 24th Jan 2023 12:57pm
SpitfireS
Germany 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
This week I had the battery on a cheap Aldi 12V charger for a couple of days (!) and the FBH would not start.
Outside -10C.
The car started normal.
Now I read charging an AGM with a normal lead battery charger only gets the AGM battery to 85% of full charge.
As if the charger is draining the battery... (I don't think so but it might not really charge at all if the AGM is at 90% or so)
This may explain why the FBH didn't do anything while parked and on the Aldi charger.
The FBH does work while parked without the charger connected, also around -10C.
Next thing to do is find a proper AGM charger.
Preferably compact so it fits somewhere in the engine bay (TDV8) with the hood closed. 2012 4.4TDV8
2000 Honda S2000
Post #710629 30th Jan 2025 10:13pm
