Home > Technical (L322) > air con noise
air con noise
when i switch on the a/c i get a kinda screeching noise, sounds like a fan on steriods and no cold air ..gas in system and normal blowers work...any ideas please.
Post #71170 4th Jul 2011 7:22pm
Rolo
United Kingdom 2012 Range Rover Vogue SE TDV8 Orkney Grey
slipping belt ? possibly the compressor bearings causing it ? When the air con is on it creates quite a load, so any slippage can squeel.
Might just need a new belt, they can get "polished" especially if there has been slip.
Post #71451 6th Jul 2011 7:50pm
the noise isn't in the engine bay but behind the dash...strangely it went away for bit but now has come back...i'm thinking a fan is starting to seize maybe..
Post #71498 7th Jul 2011 8:31am
Rolo
hmmm, don't know then....time to get the dash apart ! good luck
if you can get to the fan motor would some of that electrical spray work to lubricate/clean?
something like this http://www.ekmpowershop13.com/ekmps/shops/...-285-p.asp
Post #71507 7th Jul 2011 10:01am
thats my thinking, get the spray in there and see what happens... Very Happy
Post #71513 7th Jul 2011 10:43am
