Home > Technical (L322) > height sensor issue
mgrover
height sensor issue
So recently I changed both left and right struts with Aerosus ones.
I got the above two faults from the sensor.
So I thought huh, it's probably cause I let the hub drop to the ground, probably upset the sensor.
So replaced the sensor today, still same issue.
So now am thinking could it be the wiring? I've ordered a wiring repair kit but is there anyway for me to confirm this?
The suspension seems to be working fine, but the car is dropping overnight and theres no leaks. So am guessing the wiring could be getting the wrong info? Its actually a sport Sad
Not anymore, 4.4 TDV8 now Very Happy
Post #655145 30th Jan 2023 3:40pm
