Home > In Car Electronics (L405) > Electric window fault
When was the last time you found an electric window didn’t work?
You could get in a 1990 Ford and it would still be working- shame the Land Rover build quality is here yet again.
Drivers window bangs inside the door on its way down and stops, struggles to open, then becomes unresponsive. Booked it in with the dealer who can very conveniently see me in just over a months time, so, I’ve basically got to not use my window for a month. Unreal.
Have a little video but not sure I can upload it here. Discovery 4 HSE
Post #655154 30th Jan 2023 4:49pm
I got LR Assist to come out today.
The guy said he’s seen this many times on the Range Rover and Discovery. The glass comes out of the runners inside the door. He had it fixed in 20 mins after removing the door card. Discovery 4 HSE
Post #655271 31st Jan 2023 6:19pm
Beat me to it sir... Had this a few times on 405's... As you say, an easy fix... Thumbs Up
Post #655314 1st Feb 2023 1:21am
An easy fix...when you know how! As with all fixes. Discovery 4 HSE
Post #655343 1st Feb 2023 1:56pm
Well to finish this thread off for the next person who gets this….
The problem arose again. LR Assist (AA) came out and took the door card off again and I insisted nicely that I see inside the door to eyeball the issue.
It turns out the front of the glass slides down inside the door within a wide felt runner that is a rubber length, just held into a metal channel.
That rubber was hanging down, out of its channel. This explained why the window became really slow and was creaking on the way down- it was effectively trying to re-seat that rubber channel as it went down. Could easily knacker the motor doing so. Even though it had been pushed back in it clearly just wants to come out so we cleaned it with degreaser and glued it back in so that hopefully it doesn’t happen again.
LRA don’t carry any glue on board but I had Gorilla Glue epoxy mix stuff and we spread that down the rubber. Discovery 4 HSE
Post #658147 1st Mar 2023 9:41am
