Home > Technical (L405) > Converting a TDV6 to a TDV8 L405?
Jase71
Australia 2017 Range Rover Vogue TDV6 Santorini Black
Has anyone ever converted a TDV6 to a TDV8 on an L405 on an occasion such as a crankshaft failure or other reason to change the engine? Just interested to know..is it even possible? 2017 Range Rover Vogue V6 Diesel
2006 Range Rover Vogue V8 Diesel - gone
Post #655528 3rd Feb 2023 10:12pm
Vogue
The V8 Diesel has a different suspension set up, not that is probably strictly necessary but just a thought to add into the equation 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #655533 3rd Feb 2023 10:49pm
Arch Stanton
most things can be done, it may not be cost effective or mechanically effective though. If it happened to me I'd be tempted to have it broken for parts Onto my 2nd FFRR, this time an L405 5.0L SC AB in SVO Palette black.
Post #655537 3rd Feb 2023 11:41pm
cass
I’m sure someone like Allan Millyard could do something like that but I’m sure it will be beyond most normal people
Post #655538 3rd Feb 2023 11:45pm
mjdronfield
He’d fit a V10 instead 🤣
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #655539 4th Feb 2023 12:06am
Mikey
It is possible, but not practical
You'd be cheaper to sell the V6 (broken or not) and but a V8...
Post #655555 4th Feb 2023 9:44am
cass
Nah - I recon he'd build and fit a V7 just for the hell of it
Post #655577 4th Feb 2023 2:25pm
fisha
The suspension is only different in terms of the active aspect of it … which works in addition to the actual setup does it not? i.e. the physical arms and struts are the same across both,, but the SDV8’s anti roll bar has an active central component and active dampers, where as the V6 doesn’t. In reality, it’ll just mean a bit more lean on cornering etc … and maybe the damper rate will be different
The different in engine weight will be countered by the self levelling, so that wont matter so much.
What else may differ ? Bellhousing, diff housing maybe, a ton of pipe work and radiators possibly, plus programming the car to it all too.
Easier to fit the same engine, but fixed ! V8 or else ...
Post #655635 4th Feb 2023 11:05pm
Or more likely a Spitfire Merlin/RR engine... Whistle Thumbs Up
Post #655643 5th Feb 2023 12:45am
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
Cam-Tech-Craig, Now you're talking. What a sound that would be. Thumbs Up
Post #655666 5th Feb 2023 11:19am
