![]() | Home > Technical (L322) > Anyone know what these do? |
Danb_220_2019 Member Since: 02 Jan 2023 Location: Suffolk Posts: 262 ![]() ![]() ![]() |
Options or specification configurations that are not fitted to your vehicle. Manufacturers use a standard wiring loom where possible to reduce supply complexity. Don't worry about them. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
Snowy90 L322 Member Since: 24 Aug 2015 Location: Surrey Posts: 226 ![]() ![]() ![]() |
yes i gathered they were for certain options, i was hoping someone would know what options.
Very hard to tell what they are based on that picture as it's too small to see the detail, but neither of those look like audio wiring at first glance, but rather something like small module power connectors. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
Barmybrummie Member Since: 03 Apr 2021 Location: Somewhere in the valleys Posts: 785 ![]() ![]() ![]() |
I could be wrong here, but they look exactly like the connectors for the retro fitted flappy paddle gear shift. I did it on mine and I'm positive I had to plug in the purple connecters. |
Thanks for the response, next time im routing around down there ill see if the have any power. |
I think early L322's had a phone option, in the center cubby, so maybe something to do with that. |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1583 ![]() ![]() |
My 2003 Vogue had the in-built GSM mobile phone but I don't recall seeing those connectors when I removed it and converted the L322 to Bluetooth (the 2G/GSM network closed some years ago down here). Ron B. VK2OTC
jimmie Member Since: 19 Jul 2014 Location: Warsaw Posts: 192 ![]() ![]() ![]() |
what is color and thickness of the cables? |
