Home > Technical (L322) > Air box noise
kevinp
Air box noise
While my engine has been idling during a transmission oil check I'm getting a strange gurgling, sucking crackling sound from the passenger side air box inlet on the front wing.
If I give it a quick rev it stops and can hear nothing but returns a minute later.
I know that filter is for the second turbo and I have done the actuator update.
It has had new plenum connectors.
Any thoughts please?
Thanks Kev.
Post #656334 12th Feb 2023 1:24pm
JayGee
There is a diff breather hose that outlets nr the NS airbox or I think may even plug into it 2012 TDV8 Vogue (L322)
Post #656338 12th Feb 2023 1:40pm
kevinp
Thanks JayGee. It sounds like when you're trying to suck the last bit of a milk shake through a straw. I can hear it through the inlet on the outside of the wing.
I'll take the airbox off and have a look
As far as I know that air filter should be completely inoperative at idle.
Post #656346 12th Feb 2023 3:14pm
JayGee
Looking at the workshop diagram the front diff breather doesn't go into the NS airbox but just exits nr it. 2012 TDV8 Vogue (L322)
Post #656352 12th Feb 2023 3:34pm
