![]() | Home > Technical (L322) > Should the viscous fan spin freely when disconnected? |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 ![]() ![]() ![]() |
TDV8 4.4l - as per other posts things are being taken out to fix a squeaky aux belt.
I’ve had a look over YouTube but cannot find something that shows the fan spinning… or not. The closest i have gotten to is for a LR3 far replacement. Both the old and new seem to freely spin, and the design looks very similar to what i have.
This morning whilst working on the car again, i took another look at the removed viscous fan.
Good morning Phoenix.
I must admit, it's not a test I've ever done, it does sound like the sort of behaviour I'd expect though. Do you have diagnostics capable of reading the fan speed and commanding it's lockup percentage? That would be the only way to reliably confirm correct operation that I know of. |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3875 ![]() ![]() ![]() |
I remember going to the motor show with my brother in approx 1990 when the viscous transfer box was introduced to the Classic Range Rover. ( Not sure if the viscous fan came in at the same time, but it was included)
A 'non-Newtonian fluid' - probably corn starch not baking powder though. |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1531 ![]() ![]() |
Stiff is normal. Should spin smooth, but with a smooth fiction feeling. Think like sliding a bag of flour across a worktop. It’ll slide with an even force, but as soon as you stop pushing, the bag will stop. The fan movement will be the same sort of movement. V8 or else ... |
Good morning all. No option to read diagnostics at this stage as the fan is out of the car. however its a moot point as I have taken delivery of a new fan, and… it has the same behaviour! So yes, to answer this fully… the viscous fan does turn with resistance which loosens the more you turn it. Now to organise the return of the newly delivered fan… Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1583 ![]() ![]() |
No, it’s true, not fictional. ![]() 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
I was just making it up … V8 or else ... |
RRover Member Since: 17 May 2021 Location: Sussex Posts: 278 ![]() ![]() |
Isn't this the part that does the clicky clicky noise (mine does it - more so in winter) but when owners have changed them they start clicky as per usual a few weeks later?
