Home > Technical (L322) > strange gearbox question
joninprague
Today I looked at a beauty of a l322!
they had mentioned it had some gearbox issues but they turned out to be a little strange so I wonder if it might not be as catastrophic as I or they think
Basically moving the gear lever feels a little spongy if that makes sense and it goes through all the gears really well but you have to hold the gearstick back in drive because as soon as you let go it drops back to neutral.
Do you think this could be as simple as a gear linkage issue or its the start of a gearbox failure
Its a low mileage 3.6 2007 done just over 80k
any advice very much appreciated
Post #657784 25th Feb 2023 5:54pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
Could just be a linkage probem. Does it have any issues starting if you move the gear lever slightly in park?, which would indicate a linkage problem.
Have they had any work done on the gearbox & are there any leaks. Have you driven it or looked underneath at the gear box?.
Post #657790 25th Feb 2023 6:09pm
joninprague
Thanks, No they have not had any work done to it but its about the mileage the gearbox oil should be replaced from what I have read.
it goes through the gears fine and no real hesitation goes into park it just feels a little like its not locked into D without holding the gearstick back
Rolling Eyes Confused
It didnt like going into park without a bit of force and the definite click because it wouldn't let me remove the key
Post #657794 25th Feb 2023 6:33pm
dingg1
My money is a one the linkage being the problem, get under and see how corroded it looks and get it freed off and lubed up.
Post #657800 25th Feb 2023 7:16pm
dingg1
Bloody fat finger on phone
Money on being
Post #657801 25th Feb 2023 7:16pm
Highroller
It's all pointing towards the linkage. To be honest the six speed gearboxes are pretty good. Thumbs Up
Post #657810 25th Feb 2023 8:04pm
joninprague
Thanks Gents. if I manage to get it I will get straight underneath
Post #657813 25th Feb 2023 8:42pm
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Check this out
http://www.fullfatrr.com/forum/topic47807.html Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #657839 26th Feb 2023 10:08am
joninprague
So picked the car up yesterday and drive home with out any real problems. I did have to just keep gearstick back to keep it in gear. The other gears work perfectly as do reverse. It does have an small problem as although the light shows its in park.
Its has to be wiggled to get the key out most of times but sometimes comes out with any issues
I will try to get under it at the selector cable. Also it threw up check brake fluid. I did stop at the petrol station bought some and just topped up the reservoir a bit as it was dark.
But the drive home was around 50 miles and it did not miss a beet
Post #658586 5th Mar 2023 10:15pm
joninprague
so plugged in the icarsoft and it came up with the code p0826. I have looked at the gear selector and seems to move ok but sounds a little clunky. I will attach a short video if I can figure out how Very Happy
Post #658664 6th Mar 2023 5:28pm
joninprague
so managed to upload to youtube on the link below
I am still unsure if the noise is louder than it should be just sounds a little clunky to me Shocked it still starts as long as in neutral doesn't seem to know its in park even though the light says its in P and also P on the dash. it doesn't like letting go of the key without a wiggle
I have just had delivered the new replacement so when the weather is better I can get under and replace
Post #658962 9th Mar 2023 2:17pm
joninprague
Just a quick update to say that changing the linkage worked 100%
was a fairly quick and easy fix to be honest and less than £30 Smile
So because the car has not been driven for a few months until I picked it up when driving it it seems to lack a bit of power and also the kickdown really doesn't really have any power at all.
also about 3 times on starting the engine the engine management fault appears for about 30 seconds then disappears but only happened a few times.
No fault codes showing at all...
from having a look on here I think it might be either a split hose or possibly an turbo actuator? Is there a way using the code reader I can determine what's wrong using live data? I am not so technically minded but can post results on here for advice. I also noticed these 2 pipes that are radiator hoses but just appear to be pushed into eachother is this normal? I have taken a picture
Thanks again for your help I would be lost without you Smile
Post #659149 11th Mar 2023 8:23pm
garyRR
That photo just shows a pipe clip?
Very difficult to diagnose remotely. However, lack of power on demand likely means an intake or a boost problem, although could also be ignition (injectors) also.
The simple things would be to take off both intercooler hoses (the two big hoses in the photo) and have a thorough look for splits or leaks.
Also have a thorough look around the intake manifold and throttle body for any splits (you'll likely see diesel soot in the vicinity or a sludge build up).
Any evidence of when the fuel filter was changed? If not, this is also worth changing.
If it's not intake, then it's likely a boost issue - any smoke or soot out the back at 2,500+ RPM?
I'd suggest putting it into a specialist garage to diagnose. Glenrands aren't far away from you. 2015 Range Rover Autobiography 4.4 SDV8
Post #659161 11th Mar 2023 10:20pm
joninprague
Just as a little update the brake issue was the rear drivers side brake hose was leaking so I have bought 2 to do both sides.
I still have the loss of power issue Crying or Very sad
I have checked the top hoses and they are both fine no cracks.
Using the icarsoft I took some manifold absolute pressure reading and both bank 1 and 2 had pretty much the same numbers bank 1 98kpa and bank 2 94kpa
then some commanded boost actuator control with higher rpm and they showed bank 1 at 46.67% and bank 2 at 77.65%
then higher rpm and bank 1 was 78.43% and bank 2 was 73.33%
the only error code shows p132b turbo/supercharger boost control a performance.
I know I should just take it to a garage but I am really keen to try and learn and do as much as I can.
But I can get these live readings and honestly I have no clue if they are good or not.
She runs so beautifully no suspension problems and only 87k miles. perfect interior and everything works. ticks over really well its just this loss of power issue. I have not had an error messages on the dash. just saying check brake fluid but I know what that is now.
If anyone can help it would be very much appreciated
Thanks
Post #659555 16th Mar 2023 3:00pm
joninprague
Hi All,
is there any other ways with live data that I can use to help see diagnose the p132e and strangely also threw a p2269 water in fuel condition..
Many Thanks
Jon
Post #660003 21st Mar 2023 10:10pm
