![]() | Home > Maintenance & Mods (L322) > 2nd Battery, Roof Rack, Light Bars, Solar, CTEK DT250SE |
Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 349 ![]() ![]() ![]() |
The last couple of weeks I've been pulling together all the bits needed to do some modifications for the RR ahead of Summer (Camping!). I thought this might be of interest to anyone doing overlanding type stuff, so I'll try and document and pull it all together here.
I want to be able to run camp equipment from the car (mostly a fridge!) and I intend to use some of the roof rack space to have a solar panel fitted. The idea is the solar will keep a secondary (service) battery topped up, enough to keep the fridge running without having to worry about flattening the primary/starter battery.
Good question!
Yep, there's always going to be wind noise with a roofrack - I found the deflector plates reduced the whistling as opposed to just 'wind' noise, I did try it with them not fitted and there was a positive difference with them installed. I found the wind noise was more noticeable with an empty rack, I also tried to avoid having anything too tall at the front as this increased wind noise and fuel consumption. The awnings (one on each side) I used were the Hannibal self-supporting ones, easy and quick to deploy even if it's just a 'brew stop' - The side curtains made it a useful kitchen too.
It's probably not needed to be honest, I was toying with the idea of just disconnecting it and using the hole in the roof...
Yes, it's just a coaxial connector one of these will connect directly to the back of the Nav. module https://www.amazon.co.uk/Connector-Receive...B08S75WCDL leave the LR one where it is, you could mount the replacement in the high level brake light or just magnetically through the tailgate seal onto the roof - I've seen them work adequately mounted on the rear trim by the side windows in the boot.
Right, so it's just an antenna rather than anything else, that's good to know!
The housing was designed for VICS, GPS and GSM antennas, market & options dependent, the GPS antenna is 50 Ohm coaxial to NMEA serial standard, which pretty much all the cheap ones on Amazon / fleabay are, just make sure it has a Fakra connector and it's just a plug-in changeover. |
Solar panel(s) arrived today!
That solar panel looks great, good output for the size too. what is the output voltage regulated to? |
It's a 12v panel, open circuit voltage is 22v, in line with the CTEK's limit.
Ah, right - sorry, I missed the DC-DC converter in your list! I assumed it was an all-in-one package but was confused as there was no voltage regulation in the specs. |
Yup! The DC-DC converter seemed like it'd be a more reliable solution than VSR's etc and it has an input for up to 25amp of solar at 12v, with an MPPT controller to get the best out of the panel |
A lot of vehicle charging systems are migrating to DC-DC converters, it keeps the batteries charging at the correct voltage whilst having a lower system voltage on the vehicle, which stops, or at least reduces premature ageing on electronic components. It was first introduced with hybrid drive systems but has gained 'traction' since (sorry, couldn't resist |
