![]() | Home > Maintenance & Mods (L322) > Height Sensor fault |
Goldstar Member Since: 04 Dec 2021 Location: Reading Posts: 122 ![]() ![]() |
Just checked the live values, 5 ish volts going in, 0 volts output so am I right in thinking that the sensor has failed?
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 440 ![]() ![]() ![]() |
Sensor or damaged broken signal wire from the sensor back to the ecu. Just had this on my L405, broken signal wire; much tracing later and found a damaged wire in the loom just below o/s/f headlight.
Thanks - I'll have a trace of the wires into the car first and see what I can find, if anything. Dec 2021- 2010 Facelift TDV8 4.4 AB in Stornoway Grey. |
