Home > Technical (L322) > Can I run my 2011 TDV8 with the BMS disconected?
fishyboy
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Hi all,
Since replacing the battery on my 2011 TDV8 (https://www.fullfatrr.com/forum/topic66148.html) the car has been having a few issues. This mainly involves the battery getting charge from the alternator (14.3 to 14.8v) on a run, but discharging from 12.9v when returning from a trip down to 12.3v in just a few seconds. The car always starts first time in the morning, but the voltage can be anywhere between 11.5v and 12.1v.
I have checked for a battery drain on all the fuses in the passenger area and found no drains. I haven't yet checked the engine bay fuses.
I am wondering if the issue may lie with the BMS.
To test this I was wondering if I unplugged the BMS connector from the negative pole. Would there be any issue running the car without the BMS? I would like to see if the battery revived a full charge (and retains it over night) without the BMS.
What do you all think?
Phil
Post #658579 5th Mar 2023 9:31pm
JayGee
I'm not convinced there is anything actually wrong here and I certainly wouldn't disconnect the battery monitoring system as it's essential to regulate the charging on a 'smart' system esp with an AGM battery that can be degraded with overcharging. 2012 TDV8 Vogue (L322)
Post #658597 6th Mar 2023 9:05am
V8 Bob
I think it is fairly common to see an apparent quick discharge if you check the battery immediately after a run or charging as it settles down to its actual state of charge. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #658600 6th Mar 2023 10:06am
Yep, you should wait at least 30 mins before checking voltage on a charging or discharging battery, lots of stray voltage around...
As JayGee says, it sounds normal, the BMS does it's thing, fully charging the battery like the old setup is not conducive to battery longevity.... Thumbs Up Pete
Post #658601 6th Mar 2023 10:26am
DrRob
Sounds normal for the intelligent BMS. I'd leave it alone. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #658606 6th Mar 2023 11:09am
Phoenix
It all depends upon how you are measuring the 11.5-12.1VDC, firstly, is it at the battery? was the car locked overnight and you measured after unlocking (in which case, there will be some current drain, which can be up to 30A even before you turn the key) or are you using some other method?
The comments above about charge voltage & surface charge dissipation are all valid. 11.5VDC can be low or normal, depending upon the test conditions, temperature etc.
If you were to disconnect the BMS sensor, you'll actually be putting less charge into the starter battery as the alternator control will go into a battery protection mode.
Post #658673 6th Mar 2023 7:25pm
fishyboy
Hi all,
Thanks for the replies. I certainly won't be disconnecting the BMS given the above advice. I am still somewhat surprised that the voltage on a new battery is so low after a drive (11.9 to 12.3v) yet the car still starts. I am currently checking the voltage using the 753 hidden screen but only after opening the car and after turning on all the systems (but before starting the car).
I will will try I'll monitor the battery voltage using a multimeter over the next few weeks, by disabling the bonnet switch and leaving the bonnet ajar overnight (so not activating all the electronics systems. I'll monitor the battery voltages for a couple of weeks and report.
Phil
Post #658881 8th Mar 2023 7:25pm
Phoenix
That's the best way to do it - as you're probably now aware, the '753' screen displays only the voltage at the module, not the battery voltage, and by having the ignition on, you're drawing a not insignificant current which in turn will cause the voltage to drop slightly. It would also pay to record the ambient (or ideally, the battery) temperature and plot this with the voltage as it will have an effect upon the terminal voltage and help you understand any fluctuations better.
Post #658883 8th Mar 2023 7:32pm
