![]() | Home > General > Going Out on Sat to Look at a Vogue |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
Check every button works as expected, especially the air suspension height adjuster, also try low range |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35833 ![]() ![]() |
welcome to the forum neil..quite a few people have asked this same question recently , have a read and get some pointers... |
dantheman Member Since: 02 Feb 2009 Location: North: Lancs Posts: 477 ![]() ![]() |
If looking for a Vogue petrol to convert to LPG, 2002-2005 (BMW) engine is the more economical to convert, lending itself well to conversion - the Jag lump needs replacement cylinder heads with hardened valve seats.
cliffy Member Since: 17 Apr 2010 Location: Surrey Posts: 556 ![]() ![]() |
cheers guys
hopefully tomorrow ill be posting up im a range rover vogue owner all being well |
good luck .. |
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1055 ![]() ![]() |
Sorry but this is just wrong, I know they're well respected, but they make expensive hardened heads, of course they'll say you need them, but at least three forum members run the converted Jag engine on the original heads! Cliff, Try this thread for general advice when viewing a car: http://www.fullfatrr.com/forum/topic7488.html?highlight= Best of luck! ![]() P.S. Try not to buy the first one you view, I made that mistake on my first FFRR, and it was a costly one! It it really is the one you want, buy it after you've seen some more! 2012 SDV8 Vogue SE |
