Home > Technical (L405) > How much free play in the transfer box is normal
lambo911
United Kingdom 2016 Range Rover Autobiography SDV8 Barolo Black
Hi All,
I am still trying to track down why I get a thump in the drive train when I first select Drive or Reverse.
I jacked up one rear wheel and there is about 20 degrees of slack. The prop rotates in sync with the wheel so it is in the transfer box or the gearbox.
Is this amount of movement normal ?
In the photos you can see the amount of movement from the position of the Pirelli name on the tire.
Cheers
 2016 AB SDV8 Barolo black - Sadly sold
1995 RR Classic - Ex Police car - Now Sold
1994 RR 4.2 LSE - Long gone
Post #661020 4th Apr 2023 10:24am
Bora20
Canada 2013 Range Rover 5.0 SC V8 Santorini Black
Thump could be motor mounts.
Click could be an axle CV joint or propshaft u-joint.
Unsure of free play you are speaking of, but there will be some. Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #661043 4th Apr 2023 2:29pm
lambo911
I enlisted an assistant to put it into gear whilst I eyeballed the engine. There was a bit of movement but no more than I would normally expect. 2016 AB SDV8 Barolo black - Sadly sold
Post #661052 4th Apr 2023 3:20pm
