![]() | Home > Technical (L322) > Suspension sitting funny after being lifted on axle stands |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238 ![]() ![]() ![]() |
Looks like you could well have a problem with one of the sensors, ( if the back is low but the same each side ) swop them over side to side and see if the fault moves with the sensor, not a huge job. Also ( Bear in mind this is from an owner with a 2006 vehicle ) Once down on all four wheels, try recalibrating the wheel angle sensors, go to full left lock, hold, to centre, hold, to full right lock, hold for a few seconds and then repeat the process.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4347 ![]() ![]() ![]() |
I reckon it's the ride height sensors. Sometimes they get "flipped over". Worth a look-see Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
G3BML Member Since: 22 Jul 2021 Location: Glasgow Posts: 98 ![]() ![]() ![]() |
Front sensors or rear ones? Or all of them? I had a look and the lever arm of the sensors on the front seem to be facing towards the outside |
I checked the voltages this morning and the left front is reading 3.7V and the right front is reading 1.7V. Bit strange as the front is sitting roughly where it needs to be. Ps the front right sensor was replaced with a genuine item about a year ago |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 570 ![]() ![]() ![]() |
You'll be surprised how easy they get flipped over. I had the same issue once looked & checked everything. Released the senor & all back to normal.
Hi chaps, just thought I’d pop on and update this.
