![]() | Home > Maintenance & Mods (L405) > L405 climate temperature sensors where are they? |
| Fifth Horseman Member Since: 04 Jul 2016 Location: Lanarkshire Posts: 236
When the rear heater unit is fitted in addition to the four sensors for left and right floor and mid (face) ducts, there are one each for the left and right high-level vents (the sensors are in the ducts at the top of the "d" pillars). There is also a sensor on the evaporator in the rear heater unit.
| Richiesrangey Member Since: 17 Sep 2022 Location: Edinburgh Posts: 11
Many Thanks - the fault code B13DF-11 has been generated from the rear HVAC control module (there is a front HVAC and rear RHVAC module on cars with rear climate setup both with face vent temp sensors confusingly) so 90% sure it is the sensor in the duct in the D pillar as you describe. Will remove D pillar trim and see if I can access it Had no idea for the the manual where it would be located so appreciate the steer! Cheers Richard. |
B13DF-11 = Rear Right Face Temperature Sensor - Short to Ground, so likely sensor has failed.
I removed the RH D pillar trims and could not locate the duct. Suspect the duct to the RHS face vent and 90degree bend where the sensor is located run under the headlining. Will get the sensor ordered and be a bit more adventurous with how far into the headlining I investigate. Thanks any how! |
