![]() | Home > Technical (L322) > Venture Cam |
Neil E Member Since: 05 Jan 2010 Location: North West Posts: 60 ![]() ![]() |
Only used the venture cam about 2 or 3 times and that was to only check it worked about 12-18mths ago.
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
Try deleting the camera from the menu, then put it back into the cradle to reattach it. |
Mine works fine whilst driving. ![]() Gone - Range Rover Supercharged 2006 ![]() |
I`ve not had chance to delete and re-fit it yet, but I thought the venture cam was designed to be used for driving over rough terrain. Enabling the driver to see the ground ahead before he goes over it?? MY21 P400e AB
DavidP Member Since: 20 Oct 2010 Location: BN Posts: 425 ![]() ![]() ![]() |
use mine all the time while driving with horses [bit different to children] |
Avi Member Since: 24 Sep 2010 Location: North West Posts: 309 ![]() ![]() |
Can 't be used at the same time as handsfree though |
Baben Member Since: 17 Oct 2010 Location: Kyalami Posts: 165 ![]() ![]() ![]() |
Go to 4x4 info, and hit the venturecam button, simple as that. If you don't have a venturecam paired, just switch it on and the system will see it. Works while driving for sure |
Tried deleting and re-installing the venture cam but it`s still not showing, any other ideas??
I had some tribulations pairing a second camera that I was given. It just didn't work and I started to suspect it was a different spec or something. I deleted the original, left the car to sleep for 20 minutes, then started her up and switched on the cam, and it paired after about 20 seconds, repeated for the second one. They are a bit finicky.
