Home > Wheels & Tyres > L405 P400e 22" Tyre Pressures
AnnualMan
Switzerland
Seems my 2018 P400e LWB is on 22's; something the main dealer tells me wasn't even an option for the car. That appears to be true since the tyre pressure sticker in the door shut only gives pressures for 21's.
The question is what pressures should I be running? I've read talk of 33/37 ish on the forums but with the all the added weight of the batteries + it being the LWB, I'm guessing that won't work for me.
Should I just go with the recommended pressures for 21's? 2025 P550e AB
Post #662281 19th Apr 2023 4:04pm
FWIW, this is the sticker for a SWB SDV8 - but should give you an idea of the difference between 21 & 22
Post #662288 19th Apr 2023 5:07pm
is it not in the dash vehicle set up menu.. ... - .- -.
Post #662299 19th Apr 2023 6:12pm
RDR
If it helps I was looking at my sticker, ok it’s a l460 phev but they may well be similar weights.
 MY23 PHEV HSE
MY19 Disco 5 HSE - gone
My16 Disco 4 HSE LUXURY - gone
My12 Disco 4 HSE - gone
MY05 Disco 3 S - gone but not forgotten
Post #662300 19th Apr 2023 6:33pm
all the pressures are same Shocked Laughing ... - .- -.
Post #662323 19th Apr 2023 8:58pm
RDR
I did have to look twice when I first saw it Laughing and guess what… the car was delivered with all tyres at different pressures non of which matched these Rolling Eyes MY23 PHEV HSE
Post #662326 19th Apr 2023 9:01pm
AnnualMan
Switzerland
This is what I’m seeing…. 2025 P550e AB
Post #662356 20th Apr 2023 9:41am
Based on the above, the pressure differences appear minimal between the tyre sizes. Add to that the weight differences are somewhat vague - what about only 2 people ? How loaded is loaded etc.
I'd be inclined just to go the same as the 20/21 on your sticker.
Post #662357 20th Apr 2023 10:22am
AnnualMan
Switzerland
Fair enough.....I'll pretend the wheels are 20/21s Smile
To be honest I wish they were the smaller size to make the ride a bit plusher. Also not looking forward to buying snow tyres for 22's! 2025 P550e AB
Post #662370 20th Apr 2023 1:06pm
I run 22" Conti winters and have been very pleased with them Thumbs Up
https://www.fullfatrr.com/forum/topic55997.html
Post #662376 20th Apr 2023 2:12pm
AnnualMan
Switzerland
Which model specifically Alistair? 2025 P550e AB
Post #662384 20th Apr 2023 3:27pm
275 40 22 Continental Cross Contact Winter
I'm not sure if there's a further designation within that. I'm on my second set, my current ones are date stamped 2019.
There's a published list of approved winter tyres - strangely I've not found a summer equivalent - and the Conti's are the only 22's
https://www.ownerinfo.landrover.com/docume...0/G1805962
Post #662390 20th Apr 2023 4:22pm
