![]() | Home > Maintenance & Mods (L322) > what to use-removing old glue from doors |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238 ![]() ![]() ![]() |
For the thick build up of adhesives, after solvent, try using fishing line to cut most of it off.
oggy Member Since: 09 Sep 2020 Location: padstow cornwall Posts: 397 ![]() ![]() ![]() |
have a look at powerful uk and get one of their rubber wheels I have used one and can recommend it removes all of the glue and double-sided tape new vehicle purchase
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3273 ![]() ![]() ![]() |
@oggy. -is this why you mean?
yes spot on thats the one i also use tar remover which will make it soft and help new vehicle purchase
As for which solvent, as above, tar remover seems to work, especially if you can find some gel type as opposed to fluid, then you can leave some on for a while. |
