Home > Technical (L322) > Rear side markers
vs322
Greece 2004 Range Rover HSE 4.4 V8 Java Black
Rear side markers
I want to wire side markers for my tail lights, which to be on whenever the lights are on.
1. Would I be correct to get 12V from #4 on the diagram and earth them to #5?
2. If I used LED bulbs instead of conventional ones, would any 12V LED do or am I to expect the disco effect with the can bus check?
Thanks
Post #662588 23rd Apr 2023 10:00am
1 Yes
2 Yes
Post #662605 23rd Apr 2023 1:07pm
vs322
Thanks for chiming in! Always appreciate your advice:thumbsup:
Post #662610 23rd Apr 2023 2:34pm
vs322
Job done and it couldn't have been easier. My personal lighting configuration is now complete.
I grabbed a pack of 12V 0,3W warm 3000K white LEDs for 5 euros online.
As my tail lights are aftermarket (Supertweaks) and didn't come with side marker fitting, I drilled a 5mm hole into which I wedged the LED bulb. Press fit, pushing with a flat screwdriver is all what's needed.
Attached black lead to #5 and red to #4 not on the plug but onto the lighting board. Of course the two fine wires are squeezed between the backing plate and the cluster but not enough to get damaged while water resistance doesn't seem to be affected either.
I'll leave it as is for now and if this simple, dirty approach shows any weaknesses, I will tidy things up with sealant behind the bulbs, a hole through the backing plate for the wires and solderings on the board.
The intensity is just right and there's no flickering. I might proceed to replace the front side marker bulbs with these LED ones as well.
Post #662954 27th Apr 2023 7:18pm
