![]() | Home > Technical (L322) > Front seats replacement |
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 626 ![]() ![]() ![]() |
Visiting the local breakers for some freelander parts, came across a pair of front seats I just couldn't ignore. Mine are in not too bad a shape overall, for a daily driver, with everything working on them but they do show their age. The ones I found however, look immaculate. They have screen headrests but I couldn't care less about the screens so I let the breakers keep them and I'll use mine.
Thanks for the tip of swapping L/R cushions, well noted |
Epson Green Member Since: 20 Mar 2021 Location: Sutton Coldfield Posts: 114 ![]() ![]() ![]() |
I have replaced a curtain and seat airbag - they were not coded to the car. The airbag ECU is coded but not the individual airbags. Kevin 2012 L322 Westminster 4.4 TDV8 1999 P38A 4.0 SE - Sold |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
Easy to do the leather and foam just need long handle pliers to pull the hog rings. 2017 SDV8 4.4 silicon silver AB
Thanks for your input, gentlemen. I have decided to keep my original seats and replace the worn leather and maybe foam with that from the ones I purchased.
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286 ![]() ![]() ![]() |
If they are just a bit saggy and loose you can tighten the leather with a heat gun or hairdryer but you have to be careful not to keep it focussed on one point for too long |
Thanks for the tip. Unfortunately they are cracked, hardened and darkened. They also seem to have an unhealthy sheen on them. It's mainly the seat cushions; the back could be left alone, especially on the passenger side.
Old girl is back from the upholsterer.
