Home > Technical (L405) > Tyre pressure monitoring fault
Richardince
United Kingdom 2014 Range Rover Autobiography SDV8 Nara Bronze
2015 autobiography V8 diesel and getting tyre pressure monitoring fault warning on dash. For some time have had spare tyre pressure warning but always checked ok.
Suspect if will be faulty tyre pressure sensor in spare. Does a replacement sensor have to be coded in by Land Rover dealer?
Post #663382 3rd May 2023 8:17pm
Ryanmt
United Kingdom 2017 Range Rover Autobiography SDV6 Santorini Black
No coding but I believe that they need activation when bought brand new (to prevent them going flat on the shelf)
Post #663392 3rd May 2023 9:55pm
Kot
I had the spare tyre warning come up and it would disappear after 30 secs or so.
I had the pressure of the spare tyre set at high load psi, simply dropped the psi for light load psi and never had a problem since. 2018 SE SDV8 4.4 Byron Blue
Post #663393 3rd May 2023 10:24pm
