![]() | Home > Technical (L322) > Replace lower suspension arms, ball joints, rear drop links? |
pjw888 Member Since: 04 May 2023 Location: Dumfries Posts: 34 ![]() ![]() ![]() |
Hi there,
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 793 ![]() ![]() |
My opinion the drop links aren't too bad to do but the ball joint that has to be removed from the hub is almost guaranteed to be an absolute barsteward. One of mine turned into a marathon job eventually removing the hub to get it out. Yours looks quite well rusted so personally I'd get someone else to do it. |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3385 ![]() ![]() ![]() |
Get a quote from your local indy (Glenrands). I've had mine done by them as I'd seen the video's and reports of people struggling with the ball joint. Also check the outer steering tie rod joints and the ARB bushes. 2012 TDV8 Vogue (L322) |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1493 ![]() ![]() |
Only one garage has got back to me so far and Glenrands quoted almost £1,200, which didn't include full original Lemforder parts.
I have had a look today.
