Home > Maintenance & Mods (L322) > Brake judder
paulwlincs
Brake judder
Hello fellow enthusiasts , I have a problem identifying where my brake judder is. I get no brake pedal movement or steering wobble when I brake but it feels like a warped disc noticeably near side rear .
I replaced all four discs and renovated all four callipers mainly for this but they needed doing anyway .
All of this has made no difference .
I have checked all suspension bushes etc but I’m obviously missing something .
I’ve got no ABS lights lit and no ABS DTC’S .
Any help would prevent me tearing any more hair out Laughing .
2011 TDV8 4.4 Vogue .
Regards Paul 2011 tdv8 4.4 vogue Santorini black
Post #665752 2nd Jun 2023 5:27pm
JayGee
Could be uneven pad deposits. Try doing 5 of high speed brake applications like 70-30 in quick succession (on a suitably quiet road) and see if this reconditions the pad deposits on the brake disk. Unfortunately if it's at the rear the brakes hardly get any use so this may take quite a few sessions to work. Don't rule out weak bushes even if they don't look worn and there are quite a few inc ARB bushes. Also worn shocks, out of round tyres etc. I've still got judder on mine and there 's very little left to replace but it's through the wheel and only a mid pressure braking at high speed - I just live with it. 2012 TDV8 Vogue (L322)
Post #665754 2nd Jun 2023 7:03pm
Weegie
Could be sticking slider caliper pin. After a short run check each wheel for heat (don’t touch the discs just lut your hand close to them!). If one is noticeably hotter than the others that would point to a sticking caliper. John
GAP iiD BT-Sold
Post #665755 2nd Jun 2023 7:05pm
paulwlincs
I’ve got new pads and discs / calliper pins etc which I thought was the problem. Its probably a worn suspension joint I’ve not tested properly. It’s quite a wobble when you brake .
It’s also very frustrating. 2011 tdv8 4.4 vogue Santorini black
Post #665757 2nd Jun 2023 7:09pm
JayGee
Yes forgot to mention a sticky calliper slider but assumed the OP would have not missed this if they had done a full calliper renovation? 2012 TDV8 Vogue (L322)
Post #665758 2nd Jun 2023 7:11pm
JayGee
Did you fully recon the rear callipers as the pistons are notorious for seizing in the bores. 2012 TDV8 Vogue (L322)
Post #665759 2nd Jun 2023 7:13pm
paulwlincs
New pistons , seals , pins , pads , discs and caliper mounting bolts on all four corners . 2011 tdv8 4.4 vogue Santorini black
Post #665766 2nd Jun 2023 7:58pm
