Home > Maintenance & Mods (L322) > Experience Modifying Suspension Height with IID?
garyRR
My partner gets a little travel sick from the "floatiness". I personally like it.
What are people's experiences with lowering the suspension settings with the IID, and by how much?
I read on a previous post that 30mm would be the absolute maximum and should also involve re-torqueing the suspension component bolts to prevent bush wind-up. I was wondering if even say 15mm would make a difference to stability at speed and around corners. 2015 Range Rover Autobiography 4.4 SDV8
Post #666619 14th Jun 2023 11:19pm
jimmie
Poland 2004 Range Rover Vogue 4.4 V8 Epsom Green
lowering suspension will make it even more soft.
Post #666626 15th Jun 2023 1:35am
JayGee
If it’s’s ‘floaty’ you need new shock absorbers. Most think the later cars are too firm so careful what you wish for…. 2012 TDV8 Vogue (L322)
Post #666628 15th Jun 2023 6:34am
garyRR
It's not the shocks / any issue with the ride. I'm just asking for people's experience, knowing some members have adjusted the suspension height settings. 2015 Range Rover Autobiography 4.4 SDV8
Post #666645 15th Jun 2023 9:08am
dingg1
I lowered mine by about 10mm all round for a while, you get a feeling of being able to throw it around corners a bit quicker, certainly felt more stable, give it a go you can put it back easy enough to standard...
Post #666648 15th Jun 2023 9:20am
JayGee
I ran mine 12mm lower all round as I have 255/55 R20 tyres so this is actually setting it to stock ride height. Didn't notice any difference in handling and preferred the taller look so put it back up. 2012 TDV8 Vogue (L322)
Post #666649 15th Jun 2023 9:26am
you can get a more solid ride by changing the tyre/wheels to a bigger diameter/lower profile. ... - .- -.
Post #666650 15th Jun 2023 9:40am
jimmie
pos51 is strong drug. Wink
Post #666708 15th Jun 2023 6:23pm
dingg1
Post #666715 15th Jun 2023 7:34pm
jimmie
Syntetic drug invented by Elmo McElroy. Very popular in UK a time ago (joke). Unless suspension will not hit bumpers then lowering in l322 will not make it more stiff. It is impossible due to l322 air suspension construction.
Post #666717 15th Jun 2023 7:47pm
