![]() | Home > Technical (L322) > Front airbags leaking |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
Hi all
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3329 ![]() ![]() ![]() |
Given that your shocks are 13 years old, I'd probably be replacing those as well as the bags as complete units.
Thanks.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3271 ![]() ![]() ![]() |
If you’re doing them yourself Andy, give the bottom bolts a good soaking with penetrating oil. They can be a sod to get out. |
I see you have a 2012 - did you fit non damping ones to that? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
The thing to do there is to loosen the bolt with the 22mm socket so that it rotates. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
We've got an Ingersol Rang impact wrench that runs on the compressor and is rated to 1830nm of torque. With an impact socket on the head of the bolt working it backwards and forwards, it still didn't budge.
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1406 ![]() ![]() |
I gave up on mine, seized solid in the bore, took it to a garage in the end, they had similar difficulties, even with a borrowed bigger impact gun (wound right up) , little bit of anti seize on original assembly would have been a Godsend....
