![]() | Home > Maintenance & Mods (L322) > Rust Prevention - Thoughts/Suggestions/Hints & Tips? |
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 612 ![]() ![]() ![]() |
Hi David
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4348 ![]() ![]() ![]() |
Quite a few threads on this topic and I’ve just done my rear wheel arch areas. My new friends are Neutrarust 661 and epoxy primer followed by paint and then wax of your choice.
https://www.fullfatrr.com/forum/post667249.html#667249
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3331 ![]() ![]() ![]() |
I saw your post about those trims, that’s a shame!
Gotcha. I’d go Lanoguard all day long now.
BMG Member Since: 26 Feb 2019 Location: Kent Posts: 196 ![]() ![]() ![]() |
To stop the rot off the rear quarter panels, you need to tackle this from the inside. Water collects inside and has no drain. Remove the boot side panels and electrical stuff and have a look. If you already have rust spots on the outside, expect extensive rust problems. |
