Home > Maintenance & Mods (L322) > Meyle - L322 Front Suspension Arm Kit - Thoughts?
j3fry
Thats the same problem I had with the meyle track control arm with the ball joint on the end as it was the ball joint that had failed and had gone stiff which meant it made the steering feel stiffer
When I removed it and put it in the vice it took some force to turn the ball joint as it made a creaking noise and jerked when it moved so I’m going to replace the other side incase that one goes bad as well
Post #667591 26th Jun 2023 12:25pm
Superspoons
England 2006 Range Rover Vogue SE 4.2 SC V8 Zambezi Silver
Quote:
Do please also check out Parts in Motion. Free next day delivery and they can be cheaper than AutoDoc sometimes. I've had excellent service from them.
I did sign up and have a look but the only manufacturers I recognised was Quinton Hazell & Delphi for the Arms which were £30 more per arm. Other than them it was either Borg & Beck (no thanks), Apec, Firstline, Napa or NK...
It seems a bit of a lottery at the moment as to whats available, with which supplier and how much. Rolling Eyes Gavin
2005 Range Rover Vogue SE 4.2 Supercharged V8
Follow my 4.2 Supercharged antics -
https://www.fullfatrr.com/forum/topic63354.html
https://www.instagram.com/l322_supercharged/
https://www.youtube.com/channel/UC8ChHNSdscnJarKjBLd_IAg
https://www.youtube.com/@ChallengingClassics
Post #667592 26th Jun 2023 12:37pm
JayGee
I put Delphi track rod ends on mine in March so maybe it's these that have gone south as it does feel steering related. I need someone to turn the wheel when I'm under it to hear where the noise is coming from. 2012 TDV8 Vogue (L322)
Post #667593 26th Jun 2023 12:43pm
Superspoons
Parts arrived on Monday from Germany.
Decent delivery time ( I wasn't in a rush ).
I'll update my main post with progress swapping them out. Gavin
Post #668608 7th Jul 2023 5:42pm
Merchy
When changing the lower arms remember that the car has to be back on the ground before the bolts are fully torqued up to the recommended setting. (best not to ask how I found that out Whistle) Personally I would always use new bolts, genuine bolts are not expensive. Advice is in the 'Wiki' section somewhere.
Post #668612 7th Jul 2023 7:42pm
Superspoons
Hi Merchy - Yes, good shout out - always tighten on the floor / jacked up. I've done a few of these now and took advice on here beforehand Thumbs Up
I documented here for my latest one Smile
https://youtu.be/FjA2qEyRYP0 Gavin
Post #668789 10th Jul 2023 10:58am
