![]() | Home > Technical (L322) > Burning Smell from Engine Wheel Arches |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7995 ![]() ![]() ![]() |
Oil burning or electrical burning? Could be the O rings at the rear of the engine if it’s oily smell. Can’t help if it’s electrical.
TeeMyob Member Since: 22 Jun 2019 Location: Javea/Manchester/Abu Dhabi Posts: 213 ![]() ![]() ![]() |
oily, are the o ring seals a big job ? |
https://www.fullfatrr.com/forum/post576267.html
Yeah. I think there is a how to somewhere. Not done them myself but if you take the air inlet box off under the windscreen with the bonnet open I believe you can get to them.
Don’t forget that the fuel burning heater is under the near side wheel arch too, but prob not that as it’s probably too warm for it to come on.
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1424 ![]() ![]() ![]() |
Brake caliper sticking? Only Range Rovers since 1988 |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1486 ![]() ![]() |
My initial thoughts are:
thank you all for your responses |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3336 ![]() ![]() ![]() |
The smell tests;
Yes, the local independent has told me its the oil cooler and its £1000 to fix thank you |
Some folk have got away with just replacing the gasket in the cooler, but mine had warped so needed a new cooler. There is plenty of flushes to do on the coolant if it’s got oil in.
Thanks.
