![]() | Home > Maintenance & Mods (L322) > Rear toe arm replacement TD6 |
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 766 ![]() ![]() ![]() |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3289 ![]() ![]() ![]() |
It's a difficult job in that the bolts will be seized. The subframe doesn't need removing but you would be also advised to get the outer upper and lower ballpoints replaced at the same time. Having air suspension has nothing to do with it so find a specialist Land Rover indy to do the work. BTW it looks like you have some issue at the front that are not just tracking ( steering tie rod adjustment) 2012 TDV8 Vogue (L322) |
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 710 ![]() ![]() ![]() |
The air suspension is not related and a total red herring by the garage.
PS Looking at the 4 wheel alignment report, it looks like there are LH front camber problems as well as toe-in being way-out.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8725 ![]() ![]() ![]() |
Can I suggest getting someone who knows what they are talking about to check all the front and rear arms, bushes etc
