![]() | Home > General > Impact of different sized wheels on warranty |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1673 ![]() ![]() |
If they are a Land Rover approved wheel (original or accessory fit) then your warranty will be safe. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35838 ![]() ![]() |
pretty sure all supercharged fullfat's came with 20'' andy....and i think they also came with brembo brakes which the 19'' wheels wont fit around, hopefully someone will clarify this.... |
19s fit over my brembos on front |
PJS Member Since: 06 Jul 2010 Location: Yorkshire Posts: 506 ![]() ![]() ![]() |
I could imagine you having 19" on the front and 20" on the back.. would be strange ![]() |
Andy D Member Since: 03 Oct 2010 Location: Surrey Posts: 93 ![]() ![]() ![]() |
Thanks everyone, I'd rather stick to 20s but there's a huge price difference and also the (ever so slightly) smaller wheels are supposedly better in the snow - this is a big problem in Surrey |
when we had the snow last/this year my very wide 20'' coped easily, so your standard size 20'' will be ok..remember its the range's four wheel drive that does most of the work, not so much the size of tyres. |
lrdaft Member Since: 08 Apr 2010 Location: United Kingdom Posts: 60 ![]() ![]() ![]() |
Last year in the snow I switched from 22 inch to 20 inch and noticed absolutely no difference put on general grabber at 275 /45/20 what a difference!!! 2011 4.4tdv8 vogue black with black
Thanks everyone, to be on the safe side I should probably check with Jezza at LPR - he's the man!!! '07 Supercharged in black with drug dealer tinted windows |
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 ![]() ![]() ![]() |
Check inside your manual in the tyre pressure section, it will probably have different size wheels, also there is a sticker in the door pillar area that has similar info. If it gives the options for different size wheels then you are covered as this implies suitability of use. No longer FF owner but still interested. Present car Jaguar XE
I take it they were the new General Grabber AT and not the old AT2's ? How were they in the snow and Ice , I just fitted a set to my refurbished old 19" rims. 2008 MY Supercharged Rimini Red / Jet four zone climate remote park heater and no ugly kid windows. magnus satis quod turpis satis |
