![]() | Home > Maintenance & Mods (L322) > Years affected by Hedgehog issue? |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 377 ![]() ![]() ![]() |
I think they affect all models of L322 mine left the blower fans running all the time which if course flattened the battery. Mines a 2012. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
SamThomas Member Since: 12 Nov 2021 Location: South East Posts: 293 ![]() ![]() ![]() |
The "Hedgehog" resister is part of the "shutting down sequence" and can be responsible for many issues, especially flat battery ones.
PraguePrado Member Since: 09 May 2022 Location: Paris Posts: 27 ![]() ![]() |
Right, I'll go ahead and replace it. Strange that essentially all the replacement versions seem to have middling reviews as to their reliability. Will give it a shot though and see what happens. Next step is to check the wiring under the driver's sill plate and make sure that hasn't chafed some wires. |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238 ![]() ![]() ![]() |
I had a very similar fault, BUT NOTE MINE IS A 2006, so this is possibly wrong for your car, my screen seemed to have a life of it's own and would come and go at random intervals, and over time spent more time with the screen showing the LR logo and the orange light flashing, it turned out to be a faulty bluetooth module in the rear left compartment, once I bypassed that, it was back to normal operation. My bluetooth unit is the type with two connection plugs I am not sure which type you will have. I think it is the same for 2006 - 2009 ?
Aha, well that could certainly be it… I bought the truck with a Bluetooth set up installed by the former owner and, not being able to get it to work after 23 seconds of fiddling with it (audio being near the bottom of what’s important to me, coming somewhere after, oh I don’t know, getting where I’m going), I haven’t bothered trying to learn how to use it. I’ll take a closer look now at what exactly he did to install this thing. Thanks. |
Just to add to my above post, from posts I have read on here and experience, if you are not experiencing any other electrical gremlins then it is unlikely that the hedgehog is to blame for the problem. It seems that amongst other faults, one of the most common problems with a faulty MSR is lack of control of climate system air blower speeds (someone please correct me if I am wrong ) |
