![]() | Home > Technical (L322) > Split Intercooler Pipe |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3336 ![]() ![]() ![]() |
Can't you make a temporary repair with some duct tape? If not just drive it very, very gently as if the MAP sensor thinks there is low boost it will try to increase boost which could over spin the turbo. 2012 TDV8 Vogue (L322) |
hogesar Member Since: 11 Aug 2023 Location: Norfolk Posts: 34 ![]() ![]() |
It's ok, sorted another car for travelling to the airport tomorrow just to be safe!
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4348 ![]() ![]() ![]() |
DPF would fill very quickly probably Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I've also used the wrong wording...
DPF would defo fill up rapidly with a split in there...
