![]() | Home > Technical (L322) > Stubborn front caliper carrier bolts |
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 602 ![]() ![]() ![]() |
Maybe a bit of heat around the bolt …..I’m looking at doing mine this weekend |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3371 ![]() ![]() ![]() |
Impact wrench will loosen seized bolts more effectivley than brute torque load. 2012 TDV8 Vogue (L322) |
Rudyard1 Member Since: 15 Nov 2021 Location: Devon Posts: 123 ![]() ![]() |
It was only after buying my RR in 2019 did I soon discover that any tool in 3/8 form is worthless (snapped countless bits) and only 1/2 will stand the test of time. Also purchased a MAPP gas torch (much hotter flame than reg gas torch) and Plus Gas (dismantling fluid).
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3985 ![]() ![]() ![]() |
You could try using the weight of the car. Jack the front wheel up, take the wheel off, put your socket and breaker bar on the offending bolt with the end of the breaker bar on a piece of timber on the ground and then release the jack a couple of inches.
barbary Member Since: 29 Dec 2021 Location: Isle of Bute Posts: 14 ![]() ![]() ![]() |
thanks, will try those suggestions |
Ok, have tried heat, soaking in fluid, prolonged tension on the bolt, all to no avail. The bolt head is now well rounded, so conventional methods wont work now I think. My options are, weld a socket to the bolt, the additional heat may help. Or grind the head off the bolt. This latter would entail removing the caliper, carrier and disc as one unit, then drilling out the remains of the bolts. does this sound feasible? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8818 ![]() ![]() ![]() |
Think I'd take the whole hub off and take it to a lorry garage and ask them to use their 3/4inch rattle gun on it... |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1486 ![]() ![]() |
This is a shame but I do think you should have (and should) invested in a decent impact wrench and sockets. Another must for an L322. Impact wrenches work wonders at knocking stuck bolts un-done (although all of the above methods are also needed too).
Must admit I agree with the above - I have a 3/8 Milwaukee stubby impact wrench and it’s been invaluable and with it being so small and powerful it can get behind discs/suspension arms/fiddly bits etc 2007 Range Rover Vogue 3.6 TDV8 |
Heat the head up with a gas torch so it's softens, hammer on a 1/2 socket that's slightly smaller (maybe imperial) and then run a fully charged impact driver on it. Bolts and nuts seized by corrosion need shock waves to break this bond and not torque load. 2012 TDV8 Vogue (L322) |
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 433 ![]() ![]() ![]() |
I struggled with all sorts.
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238 ![]() ![]() ![]() |
As JayGee said . soften head, hammer on a slightly smaller impact socket, and try an impact gun.
FJ12Jagmen Member Since: 25 Jun 2020 Location: Danbury Essex Posts: 77 ![]() ![]() ![]() |
Had the same problem. Tried impact guns etc. Welded on 6 nuts but all broke off. My mate used an arc welder and disparate metal rods to weld a nut on. Big breaker bar and scaffold pole released the bolt. I was amazed that the threads in the caliper were intact.
Danb_220_2019 Member Since: 02 Jan 2023 Location: Suffolk Posts: 262 ![]() ![]() ![]() |
And me. Milwaukee M18 Fuel 1/2in will get most stuff off. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica. Previous V8s: BMW 645Ci, P38 4.6, P38 4.0, Merc CL500 Previous others: Honda x1, Volvo x7, Rover x6, BMW x6, Ford x1, Mercedes x2, Skoda x3, VW x2, Renault x2, Citroen x1, Mazda x3, Nissan x1, Audi x3, Kia x1, Fiat x4, Subaru x3, Austin x2, Triumph x2, Jeep x2, Hyundai x2, Lexus x1, Mitsubishi x1, Saab x2... and some others I've forgotten! |
