![]() | Home > Technical (L322) > 2005 l322 led rear lights |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1486 ![]() ![]() |
I would hazard a guess for other global markets where amber side markers are required at night on vehicles (e.g. USA). The car CCF will be programmed for that market and the LEDs will come on with the sidelights.
barbary Member Since: 29 Dec 2021 Location: Isle of Bute Posts: 14 ![]() ![]() ![]() |
Hazard a guess - I like it! |
TDV8 Paul Member Since: 30 Nov 2020 Location: Tadworth Posts: 224 ![]() ![]() ![]() |
If you mean the lower circle of the two in the rear lights then it’s the brake lights 2009 (2010 MY) 5.0 Supercharged Autobiography
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7995 ![]() ![]() ![]() |
Yes, brake lights. The other red light, lower in the unit is side light and fogs.
Ok, it's the brake lights, inside the orange lens. Confusing, because there is a dual filament bulb in the holder behind a red lens which I assumed was the breaks, but there's only one electrical contact in the bulb holder. Sidelight. Why dual filament? Who knows. |
I believe that’s the side and rear fog. Easy to see if you turn them on and see which bit lights up.
Yes, did that - foglights are below that. |
Cool. I was working from memory when I had the TD6….
Happydaze Member Since: 30 Aug 2021 Location: Wirral Posts: 108 ![]() ![]() ![]() |
That's interesting as it might begin to explain a brake light problem I have. Is there a reset of the control module and would that require diagnostic tools?
The LED cluster is the brake lamp. The twin filament bulb further down the cluster is side/fog lamp sir... |
A ha! Silly me, why didn't I think of that! I was thinking that the led part was some kind of effect as it encircles a conventional bulb!
It’s a design classic imho… You won’t be the first to get confused by the brake lamp feature I’m sure sir… 👍 |
Confusing indeed! Strange too as I powered up the led light and it worked, as did another I had in the junk stash. Plugged the original back in and all was well. A miraculous repair as I'd done precisely nothing, beyond disturbing connections, connections that were made 2 years ago when a complete new light unit was fitted and all connections protected with dielectric grease for good measure. Im happy the mot should be OK ( famous last words!!) but less so that I don't know what the fault was. Hey-ho!
Result sir |
