![]() | Home > Technical (L405) > L405 cuts out, then off road screen shows |
| GrandadRob Member Since: 01 Jul 2021 Location: North Herefordshire Posts: 243
Scroll down to my Enggine Stops thread, it’s all there.
| Bikeracer Member Since: 24 Aug 2023 Location: Newark Posts: 23
Thanks for your reply.
| cumgetsum Member Since: 03 Sep 2023 Location: devon Posts: 4
Had similar issue. Initially it wouldn't even activate the limp home mode but after a couple of wait and restart attempts it ran with "restricted performance". Turned out to be the MAP sensor, gave it a good clean to unblock the little holes, cleared the codes and it has worked fine since! Hope this helps |
| DrF Member Since: 30 Jun 2014 Location: South East Posts: 1526
Also check earthing strap in wheel arch |
| millerj90 Member Since: 25 Oct 2010 Location: Melksham Posts: 341
This may explain it: - LTB01083
| All times are GMT |
