Home > Maintenance & Mods (L405) > 2014 L405 Supercharged Service - Preventative mainternance
andy.blue.mini
United Kingdom 2009 Range Rover Vogue TDV8 Santorini Black
Morning all,
So my 2014 L405 Supercharged is in need of a bit of love and attention.
Current milage is 92K with full LR service until now (last service was Aug 2022 at 86K).
I need to do discs and pads all round along with a service (gearbox was done last year by Bodsy).
While it's out of action what else would you do thats easy or preventative?
Anti roll bar bushes, droplinks?
There is a bit of a knock on the front at low speed over bumps that needs investigation.
Post #672089 27th Aug 2023 10:38am
Bora20
Canada 2013 Range Rover 5.0 SC V8 Santorini Black
Sway bar bushings
Sway bar end links
Front forward lower control arm
Front rear lower control arm
Air strut
Engine mounts
Each of those things can contribute to front end noise. I have replaced all except for the air struts. I have 175,000 km. The struts are next on the list.
Past that, it could be the ACE Swaybar and valve unit. Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #672108 27th Aug 2023 5:09pm
